Any cure for cold weather crazing in nitro?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=48210
Author:  Pmaj7 [ Wed Aug 31, 2016 9:40 am ]
Post subject:  Any cure for cold weather crazing in nitro?
I sprayed a top with rattle can nitro, let it cure and leveled it. Then, during a move it was exposed to very cold temps in the garage. Now it's ALL crazy! Any cure, hope?
Author:  Chris Pile [ Wed Aug 31, 2016 10:02 am ]
Post subject:  Re: Any cure for cold weather crazing in nitro?
None that I've heard of short of a complete refinish.
Leave it - adds character.
Author:  Clay S. [ Thu Sep 01, 2016 11:49 am ]
If the finish is thin enough you can try re-amalgamating the finish using butyl cellosolve (retarder), but it is chancy at best.
Author:  kencierp [ Thu Sep 01, 2016 5:35 pm ]
http://www.frets.com/FretsPages/Luthier ... ator1.html
Author:  Pmaj7 [ Thu Sep 01, 2016 10:44 pm ]
Thanks gents. Much to consider. No easy answer I guess.....
Author:  Woodie G [ Fri Sep 02, 2016 6:49 am ]
We've had a couple Merrills in with really nasty cold-checking. While the builder has been good about repairs for original owners, these were 2nd and 3rd owner guitars, so not covered by warranty. Although we normally love a little aged, checked lacquer on a 40 or 50 year-old guitar, it's not that attractive on a three year old instrument.
Much like Mr. Ford, we use butyl cellosolve, but for the type of cracks we were dealing with, the cellosolve was applied to the cracks directly using micro pippettes, then after allowing a couple days for drying, we shot two 50/50 coats of thinned nitro with 5% butyl cellosolve added. We believe the problem with the Merrill finish is the use of a lacquer without sufficient plasticizers to handle the movement of a solid wood acoustic instrument, so reshooting the body ( the necks appear to be much more resistant to checking or to have been finished with a different formulation) with a thin butyl cellosolve-rich top coat addressed the issue. The down-side of the process (versus a refinish) was that the instruments showed quite a bit of settling in the crack paths, so required a level sand and buff after 6 months.
After 18 months and some outdoor, low temperature gigs over two winters, no further checking and the finish has aged well after the one follow-on sand/buff.
